Oh definitely Chris, I do wish you luck. You certainly deserve some.
Those propellers look the part.
THANKS Jim an yes i think i do as well an yes they do lets hope they do the job
cheers
Standing by for the "launch" day.......keep us posted Chris. :thumb2:
AN YES Rick will do it will be sept the 10th as thats the next warship day an this will give me time to make the rudder bigger an for makin it turn tighter if possible an cheers for your reply also
ATB
Chrisb
Those props look much more up to the job, so let's hope they give Tiger a bit more umph.
YES Ian so do i but wont know till sept 10th an hope the wheather plays ball
cheers for your reply Ian nice one
chrisb
They certainly look the bees knees Chris. Much more muscular in stature :thumb2:
HI Tim yes these props are the ones i should have gone for in the first place an yes made from bronce they are as you say more stronger in stature an should give a lot more thrust trouble is these bronce ones are a lot more exspenive than the brass ones so got high hopes for these to cure my thrust probs as two big motors are already fitted an if still not enought power then will take out them smaller johnsons motors an fit in 2 more of them monster motors an then see what happens
cheers
atb
chrisb
Chris, it seems your Tiger got some prop(ell)er claws...:rolling:
Hat, please! :smiling6:
Best wishes for Sept 10th.
THANKS Andy just got to hope for good wheather on the day or it will be a cancel an then no answers as today im makin the rudder bigger so hopein for better turning
cheers
Chrisb
HELLO GUYS
well i made the rudder bigger as i can to try an keep it in scale an a few pics an if this dont turn her i dont know what will as the rudder is now nearly 4 inches long so hopefully should give her a good turn circle what with them new props so fingers crossed all
an pic of the new larger rudder below
That looks the business Chris. If that don't turn 'er nought will!
an here in a turn to port an starboard an it looks as though the rudder should catch quite a bit of prop wash both ways
HI Jim lets hope you are right as you say if this dont turn her well cant make it any bigger without makin it look redicalouss
CHEERS Jim for your reply
ATB
chrisb
Chris,
Many thanks for the explanation, and I do understand the adjust one thing and then adjust ten.
I see your point about lifting her in and out of the water. We have a net that is supposedly used for holding down luggage in the car according to the blurb. But we use it for keeping the dogs from jumping over the seats, the pup especially. And the thought occured to me that this might be helpfull when launching and recovering 'Tiger'. The net we have is about 3 ft long and can open out to 18 inches and with hooks on all four corners. I think I obtained it from evilbay some years ago.
Mike
Chris,
Mike
HI Mike yes when adjustin things the knock on effect comes into play so its a bugger when i do have to but thankfully just makin the rudder bigger that hasnt happened thank god an many thanks for your idea of liftin tiger out with a net but no can do as this is a big model an just liftin it out by the hull its a struggle to just clear the pond concrete edge due to her wheight but cheers for your thoughts on the subject
ATB
chrisb
Fingers crossed all you determination and efforts bear fruit. Looking forward to your positive testing whenever the Tiger re-enters the 'oggin'. (Thats nautical speak for water!!!!).
