Had the right eye cataract, which virtually blinded the eye, removed yesterday.
They put an obscure patch & plastic cover to protect.
This morning in bed. Thought what is that bright light. Shut "Good Eye (scheduled for same 14 days time)"
& it was the revived eye bright white & black & items very clear & precise. Wow exciting
Writing just to re-assure that there is nothing to be worried about in this procedure. If you have
cataracts get it seen to early. I did not. Plus the cataract in the right eye deteriorated at a pace.
Procedure. A thing slipped in the eye to enable anesthetist to inject at the rear of the eye.
About 3 mins. No pain & you are not aware of anything actually happening
Into theatre. You do not see a thing. I can only describe it as bizarre. Like a trip into outer space
with patterns you see & small tinkling noise of the machine with water slightly seeping down the cheek.
Surgeon after 8 mins patch on eye. There we are Laurie went perfectly all is well. Blimey though he had only commenced.
Back to recovery room & a very most disappointing end a coffee & superb succulent egg & cress sandwiches. :tears-of-joy:
