Yeah they are great, although I guess they come more to the front in some modern aircraft with multiple switches, knobs, MFDs and what not and less so with rather simplistic WW2 cockpits. I'll have to give them a try on something more modern one day. Which kit did you use as a base?Looking great seb , nice work with the riveter . The quinta decals are excellent arent they , I used the same set when I did my il 2 m82 conversion last year . That kit did have rivets but in every other respect is stone age compared to the Tamiya one! Cheers tony
Well actually it is the other way around... I've been building 1:72 for my entire life and just recently (in the last few years) start to play a bit with ship models in 1:700. And yeah, the wings are rather huge and would be rather bland without riveting detail.Wonderful Seb, putting your skills from 1/700 to 1/72 makes details stand out even more. The large wing of the Sturmovic is so similar to the Heinkel 111 and needs the rivet detail to add interest.
The Zvezda Il2 m seb , a simple little kit but perfect for what i had in mind https://www.scale-models.co.uk/threads/ilyushin-il2-m82-cut’n’shut-simon-t-tribute-gb.36448/.Which kit did you use as a base?
Wow great job, Tony! I know of the M82 powered Il-2 but I think yours is the first model I have ever seen of it!The Zvezda Il2 m seb , a simple little kit but perfect for what i had in mind https://www.scale-models.co.uk/threads/ilyushin-il2-m82-cut’n’shut-simon-t-tribute-gb.36448/.
Cheers tony
Thank you Karl! It is an imposing bird for sure and was lucky enough to actually see it flying in 2019 at MAKS.Quite possibly my all time favourite WW2 plane, looking good so far.
Don't often get jealous but.......Thank you Karl! It is an imposing bird for sure and was lucky enough to actually see it flying in 2019 at MAKS.
I find that statement slightly odd, given you started with a black base coatAs I always paint from lightest to darkest colour
actually the reason for it is the light feathered overspray. doing it light to dark, you get much better looking feathered edge than the other way around.I find that statement slightly odd, given you started with a black base coat :smiling3: “Start with the lightest colour” is good advice over a light base (because then you probably won’t have issues with the paint not covering that underneath well enough), but when the model is black I kind of think doing it the other way would be better?
Yup...that works for me even for my illustration days...less dustier effect.actually the reason for it is the light feathered overspray. doing it light to dark, you get much better looking feathered edge than the other way around.
