Thanks for the comments Gentlemen. So, a little update. I'm skipping around the build order a bit, so am building various sub - assemblies, starting with the engines. Now then, the instructions would have you insert the exhaust manifolds at this stage.
But then how can the be painted later ? So, a little experiment, can I build the engines leaving the front spinner assembly off, allowing the manifolds to be inserted later ?
Well, with the help of lots of blu-tak, yes.
The engines are made of 4 parts (plus the front) and a bit of an unusual shape.
And when you're done, the front pops off allowing plenty of access for the exhaust manifolds to be fitted later.
The fit of the parts is really good, so painting shouldn't be a problem, I think. The front may get stuck back on with blu-tak again.
