Scale indicator, which way is correct? eg: / or :
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
When you (and others) are stating what scale the model is, some have it like this...
1/35
and some have it like this...
1:35
So which is the "correct" way, and if so why?
....or does it really not matter.
As I don't know which one is the "correct" one, I tend to flip / flop and switch between using both, but the OCD in me wants to know which way I SHOULD be doing it!
I've been using "/" for over fifty years when it comes to model scales, even though I did get a GCE in Technical Drawing and I ain't changing now! (y)
I end to use both interchangeably, mostly because I simply don’t think about it. However, as I usually do figures my go to is mm……
When I did technical drawing at college, then later my C&G in AutoCAD, and later still when I did floor plans on CAD as a Surveyor, few years back, I'm pretty sure we always put the scale using ":", eg: 1:50 or 1:100, etc.
Just was not sure if there was an accepted convention for scale model kits, but looks like there is not, so....
I tend to use / rather than : , no real reason . On the kit boxes most makers use the slash , as far as I can tell only Airfix use the colon and then at certain periods they have used the slash too .
A colon indicates a ratio, a slash indicates a fraction. For a static comparison there's no difference.
Hmm, interesting, so a ratio compares quantities or sizes or parts, whereas a fraction (generally) represents a part of a larger whole.
So, (arguably) IMHO the ratio is a better description of a scale model, as it is comparing the size of the (generally smaller) whole scale model, to the whole real thing.
Whereas, we are not really describing a part of a larger part, eg: we may be building a half or 1:2 scale plane, but we are not literally building half of the plane!, eg: the front half, or the rear half, or the top half, we are building the whole thing, but at half scale or 1:2.
Based on the above I think the ratio - : - is the better way to describe scale rather than the fraction. (y) :)
Well, you'd never build 1/72 of a Spitfire, but every dimension of the Airfix kit is 1/72 of the original. Both : and / are correct for a model.
There was a time when Airfix did without the "1/" completely:
I doubt that anybody would think that the contents would be 600 times greater than the original subject...
WELL GUYS i always use the 1/32 on my post when discussin scales of the models
chrisb
In my model railway days I worked in 1/76.2 (1:76.2 as you wish), but we called it 4mm to the foot…….in fact, UK railway scales were known by the mil number, 2 mil was N gauge, 3 mil was TT, 4 mil was OO, 7 mil was O, etc…..
And to throw a spanner in't works........ Since i got back in to this hobby over 20 years ago i picked up the habit of calling armour in 1/72 or 1/76 'braille scale' :LOL:
