Neil Merryweather
Well-known member
The next stage is the leather jerkin.
Here’s our image again to refresh your memory
I rolled out a sheet of clay and cut it to shape for the left front. I added the seam detail but as you will see a lot of it got lost during the process. But the bits that survived helped, so I would still do it again
I added it to the body. Just to be on the safe side I painted the area first with a weak mix of putty and IPA, which is recommended by the manufacturer.
I started to model the folds as per the image and realised I had made a Rookie Mistake –
The clay just wanted to sit right into the waist instead of hanging obediently in space like the garment. So I had to peel the clay away and add some bulk underneath to support it
This made it a whole lot easier to work with
I cut away the excess at the sleeve and worked in some more creases and texture.
When sculpting clothes that are hanging it’s vital that the creases are straight and vertical or they just look wrong. This is where having reference images really helps. It’s actually quite hard to do with soft clay floating in space! It’s not there yet but I will continue to tweak it as I go along. Next we go the left side, and this time I remembered to add some bulk to support the drape of the jerkin.
I cut a piece to shape as before but this time I folded the front neck over as the image shows
I painted the area with IPA again and attached the sheet.
Creases and texture added
Now for the back, and here we have to use our imagination for the folds etc
Because the jerkin is not done up it will hang loose from the back so I added some bulk as before. Then a small piece of rolled out clay to complete the skirt
I blended that into the sides and the material at the top of the back
And added creases, bearing in mind that the right shoulder is raised so the skirt edge will slant down toward his left side. We can see this in the image.
Next I refined the creases and texture, and added the button holes
I have left the sleeves open as the arms are going to be separate.
They are a bit thick but I can’t make them thinner without breaking them so I will try and thin them down after he is cooked
A modern reproduction of the jerkin has this random seam at the back so I have added it, although it may be a modern day expedient with large hides being less readily available., but it's too late now, he's in the oven!
That’s all for now, next up I will look at fitting his head properly, working on his neck and shirt collar
Neil
Neil
