1/35 TAMIYA StuG 1V
I found methylated spirit to be even better than IPA but I don't know if it has any effect on glue joints.
Hi Pete, didn't think of that, but as I had the IPA in stock used that.
Need to filter this lot some how, as don't really want to ditch it, any ideas ?
John.
It will still work even if coloured with paint residue. I’d be quite surprised ifit could be filtered as the paint it’s taken off is dissolved in the IPA.
Glad the IPA worked so well. Model looks totally "unpainted".
I reckon Tim is right in that the paint has dissolved into the alcohol and so won't filter out.
Well, paint settles in the tin/jar before it's sprayed so I wouldn't be surprised if it dis the same after being dissolved. Not so sure about filtering, but it's worth a try.
Have some coffee filters coming so will give it a try. Each time I've changed the container there's some in the bottom, and the colour of the "soup" is lighter.
Took the lot off Jim, including a sprocket! Will try , but I can't see the colour going completely in the IPA left
I'll try to filter it Pete, used a large Ice cream tub volume of IPA , would be nice to save some
