Made a start on the undercarriage yesterday . The u/c legs and bays / doors are really nicely detailed , the mainwheels and tyres especially - equal to any resin replacement . Astonishing when you think the kit was first tooled in 1978. I had to fit a couple of thin strips of styrene strip to the front part of the main bay so the front doors would fit flush . These doors hang open slightly when the undercarriage is extended so I had to get a good fixing via the strips . I also had a look at the pitot tube , the kit version had two mould seams and a couple of sprue attachment points to get rid of , so I decided on a homemade brass replacement using tube and rod . This has a funky red and white stripe scheme ,but unlike the delta dagger ( spiral ) this ones a straightforward hoop type. Next up heat staining on the rear fuselage .
