It happens most of the time but it will be seen in between the equipment and would be hard to get to if it was painted later.You spend all that time painting the camo pattern for it all to be hidden by equipment :crying:
Hi JohnAlan
You have done a great job on painting those figures. They will look fine in your excellent dio. If I can add just one suggestion for your next figures. The uniform is very well painted but it looks a bit flat. I would suggest you take a slightly lighter mix of the lightest colour and add some small highlights to a few areas near the shoulders and the top facing planes. This will make your figures pop even more.
It was indeed wasn't it Ian.Martin; "The night shift" on you tube did a very nice demo on painting figures with glazes over black and white primer. How that would work with a camouflage I know not but the result was rather good.
