New to forums
Torsveldt
Hi, Never joined a forum before. Middle-aged ex-modeller here. Recently thought I'd get back into it after 30 years. Used to build 1/600 ships, 1/72 aircraft and tanks of all scales. So I figured I'd buy one of each to get started again. HMS Rodney went well, 1/56 scale Matilda is halfway built. I also bought a Monogram 1/48 B-29 Superfortress which unfortunately didn't have instructions with it.
Does anyone have the instructions to Model number 5706 B-29 Superfortress please?
Hi,welcome to the forum I'm sure someone here will steer you in the right direction regarding instructions.
Hi Mark1, thank you. Hopefully at some point I will prove to be of help to someone on here as well.
Hi Neil
Welcome to a great forum. Very friendly with many skilled and experienced modellers. Someone will be able to answer any questions you may have in a polite helpful way. I am sure you will enjoy your re-found hobby. I look forward to seeing some of your work.
Neil,
welcome to the forum - as you've found, the forum members have a wide range of experience & knowledge, so if you need any advice, or answers, you've found the right place! All genres of model making can be found, unlike other specialised forums..............
Neil,
And it's a warm welcome from me. You seem to have all the bases covered when it comes to what you like to build so I look forward to seeing them.
Hi Neil, welcome aboard. As it is help has reached you in a jiffy which is what this forum is about. I build dioramas...a genre you could try too.
