Good call on labelling them Jim. I got myself on a right twist doing these.Scottie, John and Si - thanks. Appreciate you looking in.
Next job was to correct an error in the kit. The plane Airfix used to base the model on had been converted to a target tug which meant some details of the bulged bomb bay doors were incorrect. This is what Airfix provide for the rear of the bomb bay.
Using Milliput, then Plastic Putty and finally Mr S 500 it was corrected.
Next up the exhausts. Very clever way Airfix devised to make sure all 4 sets were right.
I kept each one carefully labelled.
By rights I should have drilled out the ends but I chickened out as they are so small. Hopefully a black dot painted on will be OK.
I then built up the nacelles which went together like a dream.
