Having used CA at work for years , in fact since the 70s along with the accelerator I would like to join in .As CA adhesive ages it goes thicker, and produces strings, that's just the nature of the chemical.
Cyanoacrylate adhesives have a short shelf life. Date-stamped containers help to ensure that the adhesive is still viable. One manufacturer supplies the following information and advice:
Another manufacturer says that the maximum shelf life of 12 months is obtained for some of their cyanoacrylates if the original containers are stored at 35 to 40 °F (2 to 4 °C).
[43] User forums and some manufacturers say that an almost unlimited shelf life is attainable by storing unopened at −4 °F (−20 °C), the typical temperature of a domestic
freezer, and allowing the contents to reach room temperature before use.
[44] Opening a container while chilled may cause moisture from the air to condense in the container; however, reports from hobbyists suggest that storing cyanoacrylate in a freezer can preserve opened cyanoacrylate indefinitely.
As cyanoacrylates age, they polymerize, become thicker, and cure more slowly. They can be thinned with a cyanoacrylate of the same chemical composition with lower
viscosity.
[33] Storing cyanoacrylates below 0 °F (−18 °C) will nearly stop the polymerization process and prevent aging.
All interesting facts , being truthful about it a fresh bottle is always better , grabs faster doesn't it
including Bob's and our fingers .
Good morning .
