Thanks Steve.Im at work at the moment,So couldn't have a proper look\ said:There is. Images 29 and 30, with the seat removed (if I've counted right). 29 is the best showing the trim wheels and , because the seat is removed, the electrical panel/fuse box.Cheers
Found it.No cables ,But a few black panels to make\ said:There is. Images 29 and 30, with the seat removed (if I've counted right). 29 is the best showing the trim wheels and , because the seat is removed, the electrical panel/fuse box.Cheers
I've put some plastic card on the inside of the engine cowling cut outs so I've got something to glue the exhausts to .\ said:Looks nice Dave. So, what are your plans for the exhaust manifolds ? Will the engine still be in place even if not visible ? ( I have one of these to build in the future)
It's a crap kit Alan.But I have this strange desire to try to improve it and build something half decent.It will soon be time to tackle that wing dihedral problem.\ said:Awsome stuff dave , it's not a nice kit really is it but your doing a great job![]()
My idea is to fix the lower wing section to a base and support the wing tips.Then build a spar from plastic card probably about 10 mm back from the leading edge.That should stop the wing flexing when the fuselage and upper wings are fitted.We shall see....\ said:I agree mate and your doing a great job so far , I really want to see that dihedral problem and how you go about it , I found the the underside of the wings was pretty much right but the top pushed them down due to how thin the plastic is on the underside
