Ian M's 1/32 Mk II. from Revell
Staff member
Admin
Ian
Falster, Denmark
A nice little kit that went together quite well. By no means a Tamiya Ûber kit, but it looks the part and talking of parts, there are probably just as many parts in a Tamiya 1/32 cockpit than there is in the whole of this kit lol.
Clean moulding. crisp detail and OK plastic. The only oddity was a step in the wing root. Me thinks it was 'sumit' in the way in side. Everything else fitted very well. So error 40.?
Primed with Styrylrez as it was all I had in black. Preshade was white Vallejo Model color. Everything else was Model Air. I have used these once or twice on armour but this is a first on an Aircraft for me. I rather Like them. The build can be found here: https://www.scale-models.co.uk/threads/ian-ms-spitfire-mk-ii-revell-1-32.39510/page-4
Hope you like. I have a couple of the other 1/32 kites from Revell Might have a go at one later...
Comments are as always welcome.
Thank you for looking in. And thank you Pete for the GB.
Hi Ian
That is an excellent result.
Ian
That's turned out beautifully. A top notch finish.
Out of interest, how do do the gun 'soot' on the wings. AB or pigments, or something else. I've tried it a couple of times but never got it look ok.
ATB.
Thanks Andrew.
I do them with Vallejo washes. More often its just the black wash, sometimes I use the brown wash as well.
Start off the front of the wing, by the port and quickly bring the AB back across the wing. Takes a few times to get a useable effect.
Good for the exhausts as well. A oily black/brown mix with a streak of light grey works.
Beautiful finish Ian. Glad you got the markings issue sorted out.
That looks totally spot on. Great job Ian.
Ian,
That is simply beautiful. I love how the decals have conformed perfectly - absolutely stunning :thumb2::thumb2::thumb2:
