Revell 1/32 Arado 196A-3
Its coming along great guns Vaughan not long now and i cant wait to see it finished
You are doing a fantastic job on this Vaughan.
Just read the build and its looking very good! Cant wait to see the finished item.
Thanks Guys. I think I'm on the final hurdle but masking is not going to be fun I need to get the sequence just right. I'm in the process of masking off the engine so I can start on the camo.
Vaughan
Hi Vaughan
This Arado looks very impressive. I'm really looking forward to this seeing this seaplane finished.
Superb skills all round.
Paul
Vaughan its looking awesome,do'nt envy the mask job you've got coming tho! I'm sure you'll slug it out and come out with a winner!
Masking. Always a luvly job........Putting it on is fine. It's taking the stuff off I hate...I Hope you remembered to de-stickfy that tape.
Nearly There!
Thanks for the advice Ian and no I didn't it was a real struggle to get it off in places. I've had a bit of an issue with the tape or rather greasy fingers. The planes had a lot of handling over the last few months and I don't think I've been washing my hands enough so the tape has been pulling the paint off in places, we live and learn. So there has been plenty of touching up but I'm getting there. Will try and do some more today there's still lots to do like adding all the dangly bits, attaching the engine and all the inspection covers, a light misting of dark green to tone down the camo, a couple of coats of Klear, applying the decals, weathering the list does go on a bit. Anyway here are some photos.
Vaughan.
very nice there vaughn ... really fancy doing this aircraft one day ....rgds Lindsey
Hi Vaughan,I just checked in to see how this one was getting along and getting along it certainly is! Despite a few tribulations you have to fix in the paintwork it looks absolutely superb. I always find that the final stages take me forever,waiting for various coats to dry etc,but you know this will be worth it.
Superb job vaughan , its really starting to look mighty impressive! , cheers tony
Thats a great finish you have on that paint! bummer with the tape pull but as you have said, you only need to forget to wash your hands once, or scratch your nose and trouble lies ahead.
I am sure that you will not be able to see once repaired.
I must confess to having an urge to build one of those as well its on my list of German aircraft i would like to build. So thats up to four now!!! lol.
Really impressive stuff Vaughan....Nearly there now!
Although I haven't posted much, I have been watching this from day one, and what a treat it has been to see it come together, well done.
Ron
Looking real good now Vaughan. I hope I don't upset you, but I've just remembered a tip I read about masking struts. Some folks use a straw with a slit cut lengthwise - just cut it to the right length, slip it over the strut and fix with just a couple of bits of tape. You can cut out recesses where struts meet each other and fix any small gaps at these joints either with tape or blutack. You can also use those 'bendy' straws with the corrugated sections for curved struts the same way.
No good to you now of course, but maybe in the future!
Gern
Almost there!
Well the masking is off which was a bit of a nightmare I should have as Ian said de-stickfy the tape or as Dave suggested use straws anyway it's off. The fuselage and floats have had a light misting of dark green to match the wings and reduce the contrast between the two colours. I've applied the first coat of klear in readiness for the decals. I have also pre drilled holes on the float sides to take the cables for the rudders. A second coat of klear maybe tomorrow and then on with the decals. Here's another dry run with the wings and the engine.
Vaughan
I'm loving this one Vaughan, like Ron I've been watching without commenting but it's so good! The detail is great & your painting is of a very high standard. I only hope to do half as well as you.
Patrick
