SimonT - 4x4 1/24 Esci Range Rover
Jim has said it Simon, you are a one off .
Nothing supprises me anymore when you pull one out of the hat.
That trolly jack is a prime example.
John.
Great welder. Is it a no-gas MIG?
Thanks Rick
Tim - cheers
Jim - glad you like them
Graeme - :smiling:
John - just a matter of build what you see
Pete - well spotted :thumb2: very similar to one I have
A bit of paint.....
just needs the details picking out now
made a start on the surrounding earth
tidied the breeze blocks and started on the steelwork
the shelf
another box assembled and painted
car got a black wash - I forgot how fragile VJ paints are, should have varnished it before starting on the weathering as the paint started lifting and I had to re-touch a couple of areas
Hopefully it will be ok once the wash has dried out
Great looking paint work on the Land Rover Simon.
But the tools are great looking miniatures in their own right, love the Mr T's Auto Parts label on the boxes.:thumb2::thumb2:
Looking forward to the next update.:smiling:
Fernando - thanks, the tools were good fun to build
Rick - :smiling: not sure about awesome, better at building than painting, but it is progressing......
steelwork wet brushed with red to make the red/brown more red
bottom few blocks of the wall dry brushed with green/yellow mix to try give that slight mossy damp look
grass brushed with green and yellow oil paint
started weathering the body panels by dotting water soluble oils all over it - white, yellow ochre and burnt umber
first layer brushed out with an AK streaking brush and a little Medea a/b cleaner
I found that the water oils were quite stubborn when it came to blending them in but I think the slightly blotchy pattern adds to the wear
when this lot has had some drying time it will get some more highlights to fade the paint more - if it works that is............
Just caught up on this one Simon, and may I say some fantastic work, really liking the tools you've made.
Ian - you may, thank you
Quick update time
The good thing with the W&N water oils is that they are touch dry overnight so I got another layer on last night
A pale mix of yellow ochre and titanium white this time to fade the base colour out a bit more
once this is dry I will add a little more burnt umber to create a few more streaks and darken panel lines
Hi Simon
The effects of a hard life are building up nicely.
Just amazing. PaulE
Jim / Paul - thanks both :thumb2:
jack got the black bits painted in - hand grip, wheels, lifting plate
as did the welding set - end plates, handle, wires
Realised this morning while looking for painting details that I had forgotten to add the front door locking bar so added that
Also noticed I had missed the rear wiper arm spindle and the tailgate gas strut mounting plates so they were added as well
blacked in all the black bits of the bodywork - window frames, mirrors, front grille, sills, door locks, door handles
found a great website dedicated to the early Range Rovers which has copies of the sales brochures listing colours and trim - I had planned to do a black interior but according to the literature they came in tan with darker inserts regardless of the external body colour
There was an option for a darker brown but photos generally seem to show cars with tan so I went with that - dry brushed over the black base coat to build up the colour
Still need work but its a start
Will also need to paint the door cards with the same tan colour
I see now your attention to minute detail, no wonder that helmet caught your eye.
Jim:smiling4:
Wonderful paint job Mr T. The weathering is looking good. Look forward to seeing the rust work. The garage is so realistic, Its amazing. Top work as always sir:thumb2::thumb2:
Jim - thanks for dropping in for a look. I am quite good at playing those 'spot the difference' picture comparison games and Russian tanker helmets are rather distinctive :smiling4: :smiling:
Steve - ta very much, rust is getting nearer
had a go at adding some bird poo along the lines of that seen in some of the reference photos I'm using
and some more on the car itself
still need to add a bird nest in the roof but I have a plan for it
seats dry brushed then given a brown wash to give some wear
front grilles seem to go grey so it got a good dry brush as well
a bit of general dry brushing before the rust goes on......
Hi Simon
Very realistic effects. All suitably crusty and rotten.
Rust effects are just so. The car port finishes are spot on. The tools are perfection. Anxious to see how you compose it all. PaulE
Thanks Jim - many years of classic mini ownership so I've plenty of memories of rusty bodywork for reference :smiling:
Paul - thanks, it is starting to come together now. End of the GB is rapidly approaching though
Mick - not sure work of art describes it but thank you
Morning all - made a good start on the rusting yesterday
interior panels dry brushed to build up colour - tan sides and grey for the boot floor based on references
added the name decals to front and back
30+ years in the stash has not been kind to them and they fell apart once wet - the front lost an E to become RANG ROVER
if I had been doing this as a showroom fresh car then it would have been a major problem as the carrier film had also gone a bit milky in places but since it is a wreck I think it just adds to the worn out look
it then got the first round of rusting :thumb2:
started by going around all the crusty holes with german camo black brown
this was followed by a rust pigment wash to stain the paintwork and add a few rusty water streaks
the rusty pigment has settled nicely on the floor pan whereI used the red oxide paste to give a suitably crusty look
I now need to repeat the process with different shades to build up the rustiness - good fun this rusting
The worn look is great Simon, with round 1 done looking forward to see how the end of the rusting will look like.:smiling:
Merry Christmas!
