SimonT - 4x4 1/24 Esci Range Rover
I see the Force is well and truly with you. :surprised::surprised:
John.
Jim - your not getting brain fade, it was way before there was an old forum. I think it even won something at Trucks'n'tracks competition in Folkestone
Paul - thanks. Must have been a full garage if you had to wheel cars in on a jack!
Si - Ta
John - :thumb2::smiling:
Scottie - if I can see it I will try and add it. The jack was based on a photo and overall dims on Machine Mart
Finished off the angle grinder
not forgetting the scale BS1363 plug of course
added some blades to the windscreen wipers
Also finished sanding down the seats and added some end panels to the removed door
then I mounted up the various bits on sections of sprue ready for primer and clamped the body in a pair of helping hands
Paint next......
What I want to know is does that plug have a 13 amp fuse ?
If you said yes I wouldn't be at all surprised !:smiling2:
My god Simon your on a roll here alright, thrilling to see what will appear next, certainly takes this to another level.:thumb2::thumb2::thumb2:
Amazed of Linc's.:flushed::flushed::flushed:
Of course John, it wouldn't work without one :smiling5:
I could go on building accessories for some time but have decided to stop otherwise I will not get the entire build finished
Day off again - had to go for annual diabetic eye checking to see if my eyeballs are about to explode
Downside is the eye drops make vision rather blurred so tricky to do much of anything but I have been able to prime the parts so that's a start
Grinder is remarkable Simon. We have one in the shop. Only use it now to cut off cat. converters for recycle. PaulE
Cheers Paul - I don't think it turned out too badly
Late afternoon when my eyes were coming back to normal I decided to get a top coat on the body - dug out my four aerosol cans of Sandglow and not one of them worked!
I have had them so long the gas has leaked out
Got a bit of a raspberry and a dribble from one can and that was it - bum
Sprayed the body and all the parts in Tamiya matt black - used nearly an entire bottle. They are far too small
Did a bit of experimenting - Vallejo desert yellow mixed with a bit of sand brown gives a reasonable approximation of the Sandglow paint, certainly good enough to create a faded exterior
May get a chance to spray on Wednesday
You can see how 3 cars are easy, four cars carefully, but 5 cars needs the floor jack. A sketch of the old hangout. Elevated ofc. was used for parts storage. Spaces 1 & 2 were for running vehicles only.
PaulE
Simon, very nice trolley jack & grinder with a plug too, what next? MIG welder? All items very familiar to Range Rover owners. Sandglow, 70's BL colour used on Camel trophy Land Rovers, none of the paint tins working is about par for the course for BL products, probably gone on strike......
Paul, sounds like some people I know, cars all over the place!
Funny you should say that Graeme - I was contemplating doing a welder but then decided I had better throw some paint at it given the rapidly approaching deadline.
Could still be added as an extra though.....
Good thought but aerosols were actually Halfords :smiling:
Another day off tomorrow so hope to get some paint chucked about
Simon, the trolley jack is a jem...grinder and plug so you. The garage wouldn't look the same without these items. The Range Rover seems to be having a resurgance in my neighbourhood...lots of new models sprouting. I didn't know we had that many mega rich to splurge on something this unreliable. Latest I heard there were gearbox problems on the Velar's.
One can't have too many vehicles. To us colonists they are like firearms. The more the merrier! I own six myself, five of which are in running condition. One of which I have owned since I was 18! (50 years and counting). Enough to fill Paul's garage anyway. LOL. Keep 'er going Simon, A MIG welder would be awesome and then some.
Cheers Rick H.
There was a time when I thought I might just be able to hold onto your coat tails but now you have just taken it up to another level. What is there not to luv about your work. You really are the Master of the Darkside from t north. Thanks for sharing Simon. It really has made my day:thumb2::thumb2:
Richard - thanks
Rick - only six, you need to get another so you can use one each day :smiling: Most I've had was three but couldn't afford to keep up the road tax and insurance on them all. As for the welder, keep watching.....
Steve - glad you like it so far, thanks
Update time......
everything got sprayed in XF-1
yet again it took nearly an entire bottle
the body parts then got sprayed in my approximation of Sandglow based on the VJ mix of desert yellow and sand brown
it is not far off and once weathered should look the part
I had forgotten how much I dislike trying to spray VJ paint but it got there in the end
I also had a moisture problem due to it being rather cold here today and the compressor running hot - even with a moisture trap every now and then the a/b would spit a burst of water due I suspect to condensation in the hose
Fitted a second moisture trap at the a/b end of the hose and that seemed to cure the problem
trolley jack painted using matt red with some clear base added for gloss sheen
drew up some cardboard boxes in cad
basic box assembled
and coloured with thinned Tamiya flat earth
and lastly - made a start on the welding set
Simon, I sold No.7 about three years ago. I Got it in 1984, Still on the road as it now belongs to a neighbor. Lovely idea with the welder, coming along nicely.
Finished off the MIG welder:
a mixture of plastic, copper, lead wire, steel wire
earth clamp
the business end c/w welding wire feeding out of the end
plug - slightly wonky but it is only 2mm long so I was finding it tricky
carrying handle
the copper plates were bent up using a small etch bender tool - 16mm side, 2mm top edge and a 0.5mm return
back of the unit with cooling grille punched from a sheet of etch mesh and the mains cable
and lastly a rather bad pic of the front with the on/off and indicator light, rotary current and high/low range setting switches
Hope to get it painted later today
Really cracking work, lovely to see it come together. Sandglow is spot on as well.....
Tim
Morning Simon
You truly are a one off. It's all good but the Mr T parts boxes and the welder are simply amazing.
Like the welder Simon, something no Land Rover owner should be without!
