SimonT - 4x4 1/24 Esci Range Rover
Cheers Rick
Thanks Fernando - Round 2, pigments coming up so read on........
jack got a bit more paint - silver bolts, lifting plate and wheels scuffed and lightly rusted, warning notice added
welder detailed - sorry for the fuzzy pic it looked ok on phone!
Pity I can't paint text very well - will have to hide it with the wires
angle grinder painted as well
added to the general crustiness with some pigments
it looked a bit bright when I'd finished so then added some thinned camo black brown in random places to vary the tones a bit
unfortunately I caught the front grille as well so that will now need tidying up as they are plastic
Have I overdone it? Possibly - I got a bit carried away, I was enjoying myself :rolling:
lastly the wheels were painted in steel and then given the pigment treatment as well
once this dries I need to paint in the wheel nuts blac, pick out the valve and the balance weights
fast running out of time before the GB end but at least I have progressed as little
Thanks for looking in
Thanks Rick - nearly there now
Just done a test fit of the main components on the base
I have decided to leave the windscreen out as the fit is rubbish - never thought to test fit it at build stage as I expected it to be suitable for the hole in the body. Wrong! Ho hum.
Front and rear lights still to sort and one or two smaller details but nearly there
Broke one of the feet off the welder removing it from the sprue handle so that needs rectifying so it sits level
Next post will probably be completion unless anyone can think of anything else or spot any glaring errors that could still be corrected......
Fantastic bit of work. even the test fit is remarkable. Windshields...who needs 'em.
Cheers, Rick H.
SIP welder, Bosch angle grinder... Have you been in my garage?
Mr T. Far be it for me to interfere in one of you masterpieces but would the windscreen look okay laid on top of the bonnet half in half out of the cab with the rubber seals hanging out??
Hi Simon
This is impressive even by your standards of mogglin' detail.
A real beauty of a beast. PaulE
Thanks Rick
Pete - sounds like we have similar items of 1:1 workshop equipment :smiling:
Steve - great suggestion. I was just going to pile it against the wall but have now wrapped it up and plonked it on the bonnet
Jim - thanks, getting there now
Paul - thank you
I know I said the next post would be completion but that hasn't quite happened yet
thanks our host John turning round my SMS paint order mega quickly the clear Tamiya paints arrived yesterday afternoon so I could paint the light lenses
the funny looking white blob down the front is a chunk of rag to sit on the shelf on the back wall - made from a dollop of leftover Duro putty with VJ sandy paste for texture
said shelf attached to rear wall. The white mess at the right side is where the Duro pulled the paint off the foam wall :sad-face:
Rear bumper and rear wash wipe reservoir also attached to base
Socket and consumer unit have been installed at the left
based around Steves suggestion I stuck the windows together then wrapped them in a Duro blanket
after a couple of hours I carefully prised the whole lot away from the car and washed the vaseline off with zippo lighter fluid
it was then stippled with VJ sandy paste for texture and painted dark green - paint still wet in pic
wheels got the nuts and valves painted black and the balance weights I added to the rims were picked out in grey
tyres were treated to some pigment and thinners
I swapped wheels around between axles until I got all four tyres sitting on the deck and then CA'd them in place
old tin of paint for the shelf - just needs handle refitting
every workshop should have an old biscuit tin for storing odds and ends - I know the painting is a bit pants (pity I didn't inherit my Grandmas painting gene - she was a proper water colour artist) but it will hardly be seen on the shelf
Definitely getting nearer to completion now.......
The paint pot and biscuit tin are inspired additions.
Looking forward to seeing all the jam jars filled with screws, nuts and bolts in the biscuit tin:smiling2::smiling3:
Cheers Steve
Jam jars, your wish is my command........
jar full of screws - well, ok, bits of brass and steel wire was nearest I could get
also did the compulsory hard paintbrush in dirty turps :smiling:
the wrapped glass on the bonnet
bedsheet for use as cleaning rags
tap and a bit of damp painted in
I think that is all the component pieces done now - just need to bring all the bits together now............
Morning Mr T,
It seems I’ve missed pretty much every update since the beginning of December....even though I flick through the site most days and it’s on my watch list!
Anyway.....Wow! Some most excellent touches, bring the whole scene to life.
Observing and reproducing all the bits us blokes keep in our garages/sheds was a great idea. I think yours is still too tidy though.... I’ve seen some garages, floor to ceiling junk, or ‘projects’ as they are better known :smiling5:
Loving it:thumb2:
Morning Si - I know exactly what you mean :smiling4: but I have run out of GB time to keep adding stuff so completion beckons
What next? I can't bear to look...perhaps some loose pocket change on the floor boards or the car keys in the ignition? Hmmmmm. This is a good show no matter what the price of admission. Cheers, Rick H.:thumb2:
Thanks Rick - don't think anything else will be added now :thinking:
All the bits are now in place and glued down
I managed to smack the roof into my airbrush extract cabinet and with it being made of thin cardboard rather than plastic it suffered a bit of damage - the paint chipped off. I wasn't too pleased at that point but only myself to blame
There will be a little touching up of paint required but it is essentially now complete
Photos will follow in due course
What can be said Simon !
Only
:thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2:
Hi Simon
Totally brilliant - nowt else to say :smiling:
Simon,
I have missed this and just had a good catch up. Inspired work and a great imagination, top work. have a happy new year from my home to yours.
You've brought another beauty home brother. Have a Happy New Year Simon. PaulE
All the components look great:thumb2::thumb2:, hope to see them together soon.:hungry:
Oh and have a happy New Year Simon.
