Dave, strange as it seems it is in fact correct.From MiniArt - 'new kit coming soon'
Rather confusing - I thought NVA meant North Vietnamese Army, but all the colour schemes are for East Germany ( DDR )
Unless NVA tanks had East German markings, I think a mistake has crept in somewhere!
In this context, NVA stands for Nationale Volksarmee, “National People’s Army”.Rather confusing - I thought NVA meant North Vietnamese Army, but all the colour schemes are for East Germany ( DDR )
And so succinctly put too......Personally I think you should use the Kummer–Vandiver conjecture.
The class number h of the cyclotomic field {\displaystyle \mathbb {Q} (\zeta _{p})}{\mathbb {Q}}(\zeta _{p}) is a product of two integers h1 and h2, called the first and second factors of the class number, where h2 is the class number of the maximal real subfield {\displaystyle K=\mathbb {Q} (\zeta _{p})^{+}}K={\mathbb {Q}}(\zeta _{p})^{+} of the p-th cyclotomic field. The first factor h1 is well understood and can be computed easily in terms of Bernoulli numbers, and is usually rather large. The second factor h2 is not well understood and is hard to compute explicitly, and in the cases when it has been computed it is usually small.
Kummer showed that if a prime p does not divide the class number h, then Fermat's Last Theorem holds for exponent p.
The Kummer–Vandiver conjecture states that p does not divide the second factor h2. Kummer showed that if p divides the second factor, then it also divides the first factor. In particular the Kummer–Vandiver conjecture holds for regular primes (those for which p does not divide the first factor).
So to summarise its easier to build something with no tracks at all :smiling5::thumb2:
No!So that's 98x2x6 = 1176 + 34 = 1210 parts just for the tracks on a Pz III/IV winter version? Is it just me that finds that ludicrous?
I don’t follow your maths Dave, but I might be having a thick day....I make it (98x6) + (17 x 6), which is 690. Still high, but if the clean up is minor, then more than doable.
I concure.I don’t follow your maths Dave, but I might be having a thick day....I make it (98x6) + (17 x 6), which is 690. Still high, but if the clean up is minor, then more than doable.
