The Border Models 1/32 Lancaster BI/III
Good to see some progress Barry. Would it be worth replacing that u/c cross piece with a bit of brass rod?
I saw lots of Lancasters at Telford.Some stunning 32nd ones with props working.Never cease to be amazed at the standard of models around at shows and on forums.I was tempted to buy an Airfix 72nd Tiger force boxing to do a postwar version.Was a bargain at 22 pounds.Seen them on e.bay for double that.
Great to see you back at the bench Barry and not fazed by a broken part. Like how you have planned to replace it at a steady pace.
Wabble
Well you still have the touch an it is so pleasing to see you back at it.
It's looking quite impressive Barry.
Well my son returns here tomorrow, just for a week. So I won’t be at the bench again for a week. After that he is back to his normal life again, as will I.
Progress this week has been good, working on the inner wings. Still a fair way to go on these but here are a few photos. Fit has been superb I have to say. I decided to have flaps up as it would be quite fragile and vulnerable down. That needed some surgery to kit parts.
Good progress. Nice to know the fit is so good, as you'd expect from a kit like this. Enjoy your week with your son and then back to the bench.
Good to see you back at this Barry and more importantly pleased to hear that your wheelchair has given you some freedom.
ATB
Time for an update. No real drama to report. No fit issues but the awful instructions are a problem for identifying exactly how some parts fit. Got there on the end, first with the undercarriage.
the mid-upper and rear turrets are well under way.
i am also working on the outer wing sections.
Good to see you back in the saddle Barry 😊
Some nice work going on there 👍
Geoff.
I have been plugging on with the outer wings. No fit issues though some filler was used here and there.
as previously mentioned am building her with closed panels and therefore leaving out the engines for which engine blanks are provided.
I put together all four engine blanks and the inner ones fitted to the wing perfectly.
However, on the outer wings I found the lower location tabs not fitting. Below you can see the inner wing with its perfect fit.
Note: I have been driven up the wall on my phone trying to insert photos into place where I want them. For some reason it keeps putting the photos at the top or, if I manage to get one where I want, I cannot move down to do some text under it. I have tried it all sort of ways but have now given up. The photos are therefore added all together without the associated text. Anyone else prefer the old forum software, certainly do, far better than this one. New isn’t always better.
anyway…
I also show a picture of how clearly the pins and location tabs don’t line up. Another how it looks at an odd angle and finally with the pins cut off looking just right (panel test dit confirms this is right).
My conclusion is that this is an instructions problem and if this kit was produced by Wingnut Wings they would have covered this in the instructions.
Certainly one or two issues Barry. Nothing you can't sort out fairly easily but they're there none the less and shouldn't be.
Well I now have come to a grinding halt and I have no idea about how to move forward.
The outer wing sections simply don’t fit to the inner wing and it’s as if they are not meant to.
I have tried a dry fit but there are substantial moulded in strengthening beams right in the way where the wing spars are mean to fit. I certainly did not see this coming!!! I cannot get in to cut those beams away either without forcing apart the wings
giving rise to all sorts of issues. I have checked and double checked to see if I missed something in the build, in the instructions, but no I have not. It’s like two different models. It is not just something a bit of sanding can resolve either and it’s not just one place.
it is difficult to see in the photo but you need all the space for the spar, plus some more and also have two vertically moulded in spars , on the inside, that block the way….
i need to think about this before making a rash decision. This is really puzzling.
Click image for larger version  Name:	IMG_7964.jpg Views:	0 Size:	190.5 KB ID:	1243148
Further to the above.
The caliper is set to the amount of plastic that would need to be removed from the wing spar to get a fit. This is a full quarter of an inch, with the spar a full inch wide. That’s a lot. Even then it might not work as taking off so much of it would affect the structural integrity of the wing join. Remember these outer wing sections are
meant to be removable. There might be ways to restore the integrity of the spar though r
I am not sure I want to undertake that as it would be a bit hit and miss, take a lot of time and may not really work very well.
I don’t know how much time I have (hopefully years!) and even then how much of that time I will be able to model. Is it worth taking time to sort this, something won’t enjoy doing. Or should I just say to hell with it, dump the model and move to another in my stash. I need to think this through.
Click image for larger version  Name:	IMG_7966.jpg Views:	0 Size:	309.8 KB ID:	1243165
That's not great. Any other build blogs online that encounter the same issue?
It looks as if parts O22 and O10 should have been left off. I might be able to reach inside the wing with knife and long nosed plyers to hack that piece apart. It might wreck the wing of course.
Click image for larger version  Name:	IMG_7967.jpg Views:	0 Size:	317.4 KB ID:	1243168
I found one the comment was simply that it took a lot of work to fit the inner and outer wings. No photos or any real information.
Just had a watch of a youtube build, and although the guy doesn't mention it at all, he has definitely cut out the wing spar.
That’s not the problem area. It is the inner wing to outer wing. My inner wings fit the fuselage quite well.
