Tim Marlow
Well aware of fret fillers Jim, seen it loads of times. Doesn’t stop it winding me up. That box one is my pet hate though. I’ve been using etch for about thirty years, and have only ever seen the box issue taken seriously by a couple of manufacturers. It’s just lazy design, propagated by someone that has never tried to actually build something. To make a box that way fold lines must be on the inside, and the ends must overlap the sides. The worst offenders even expect you to make things like railway box wagons that way…..the best remedy has always been to cut the ends off, solder them up with plenty of solder, then dress the corners back. Shan’t bother in this case though, I’ll just replace it with plastic :thumb2:I well remember when I first started modelling a member of the old MMod forum used the term "fret fillers". Since then I've always taken a very critical look at PE. Often I don't use half what's on offer. Having said that PE can be a real improvement.
