Trumpeter 1/32 TMB-3 Avenger
Looking good Barry, the cockpit looks great.
Wish Trumpy did a Devastator. Now I mention it, before that I'd like any manufacturer to do a Kate or Val in 1/32. Seems mad that there isn't a single kit!
Looking forward to the progress
P
Looks fantastic so far.Like you i hate P.E with a vengeance.Drives me mad gluing the damn stuff.
Keep it up.
I have painted some more internals. I will do some weathering in my next session after I am back from a few days away.
The instructions say the bomb bay should be tan which I thought odd. Well I suppose Zinc Chromate, as below, might look a little like tan in poor light.
Great work Barry , totally agree with you about the tiny impossible pieces of PE , how they expect you to glue something thats about 1mm long with a contact point about a tenth of a square mm is beyond me! Ive only really used PE for seatbelts and larger items , if ive ever had anything tiny like this Ive done what you did and either ignored it or used plastic instead . That said Ive got a tiny helicopter in the stash thats about 50% pe so i guess ive got to face my demons sometime! The bomb bay paint call out from trumpeter seems a bit off , all the pics ive seen of walkarounds of the TBM show it in a dark green same as your cockpit , heres a good one of an unrestored bomb bay http://www.usshornet-cv12.com/aircraft/TBM3E Avenger/slides/TBM_41.html cheers tony
Hi Barry
This is a great example of neat, skilled modelling. The results say it all. Cockpit looks excellent. A question if I may. Those Uschi metal powders. Do you treat them as pigments and sort of dry brush them into place? Do they need fixing in any way? They certainly look good.
Thanks for the link Tony. Looking at that, once I have done some washes it won’t be far off.
Hi Barry
Hi Jim
They are very flexible and can be used in many different ways.
I do simply dry brush over matt black to depict an engine for instance. It can also work for gunmetal.
I also sometimes apply with a cotton bud, the extra small Tammy ones are good in some circumstances in small areas.
I also will use a cocktail stick to depict chipping.
You can just use a finger or a cotton bud to rub it in and polish the surface to do a natural metal finish. The result of the latter is influenced by the paint colour that you apply to.
Worth getting some and experimenting.
Looking good Barry. This kit has a lot of nice detail just waiting for you to enhance.
Thanks Barry for that info. Certainly worth buying judging by your results.
As you can see there is an awful lot of 'innards' to go in this model...
The good news is that it all fits perfectly. You do need to go slowly joining the fuselage halves though. Keep test fitting and checking to make sure everything is in place. If something does not fit quite right then it will not be the model, it will be you, so check it and work out what you did wrong and correct it before the final fit. In my case I found a small gap between the firewall and fuselage half on one side. I did not try to force it but razor sawed two engine mounts on one side, these are thick strong pieces. The thickness of the razor saw was enough and the engine sprang into place. I wanted to keep some play and did not cement the engine mounts back together as there is enough plastic to join the firewall to fuselage with a strong enough join to secure the structural integrity of the model. You can see the engine mounts between the firewall and bulkhead where they wont be seen, there are two on each side.
Abover, test fitted ready to 'tac' some Mr Cement S in places along the seam. I did find a need to hold the sides together more securly with a clamp however.
You can see a casualty of the repeated test fitting, a bomb got knocked off its mount. I will superglue that back in place tonight after I have removed the clamp and tape after which I will run Mr S Cement along all the seams before sanding.
That interior is really full....loads of detail in this one, hard to believe it’s a single engined plane....great work Barry
I removed the tape and ran Mr S Cement down the fuselage seam. Tonight I will be sanding and doing a little filling.
I then got on with the engine cowl with some p.e.
The tail rudder is made to be inserted before you join the fuselage halves. But it has a very prominent mast on top and if I did that it would not last 5 minutes.
The answer is simple, cut off the location 'swivel' pin from the bottom.
Then, later perhaps after painting, I will be able to simply glue the piece into place, mast intact...
Dry fitted to check...
I will be starting the wings tonight when I have finished working on the seam.
I am taking this slowly as this was an area that gave me issues on my last build of one of these.
The wing hinge mechanism is fragile and I will not use it. I will be cementing the wings open and I will need to make sure the wing join is strong. I anticipate the use of plastic card but I will need to do a fair bit of test fitting to get it right.
A few more progress shots.
The wing main structures are done apart from some surface treatments/sanding etc. I will also need to attach some pe detailing.
The main undercart assembly done, to be painted before finishing.
I have to say that this is a nice and strong assembly, no worries about fitting this.
Tailplanes
I am also getting on with some stores assembly, trimming and sanding. A fair bit more of that to do tonight.
Barry
I am very impressed with your builds. I must say you were certainly part of my motivation to have a go at an aircraft myself. Watching carefully to pick up all the tips I can.
