After a quick clean up and check the main parts of the airframe are ready for primer . Make up sponge has been cut and stuffed into various orifices ( oo er !) to stop overspray and some temporary legs have been made from sprue and a stirring stick . A light coat of Halfords grey primer and its now curing . While its drying ive been looking at the nose wheel and leg . Its got very weak locating pins ( one of them has already broken off) so im going to have to solve this later . The other thing is the location of the nose wheel . It is supposed to go in between the two halves of the leg but the locating pins are very small and not very positive - it just looks loose and wonky! . On top of this putting the nosewheel in now will cause problems painting later so I decided to drill out the pins and put a sleeve in the nosewheel so I can add it last off using a brass tube axle
