Finally got round to spraying the Subaru RC shell yesterday.
Been a long time since I’ve done one of these but please to say it’s turned out very nicely, can’t wait to get it on some gravel for a blast around![]()
Nice bunch of wee folks Tim.... should keep you busy for awhile.Well, after a couple of aircraft and an ambulance……
They’re back…….
28mm Northstar plastic orcs from the Oathmark range. They’ve been primed for about three months so I gave them the Zenitel treatment today…..very nice sculpts, probably the best in the range so far. Looking forward to painting them :thumb2:
The two in the pictures are both by my hand.Looking good Si. Which one did your daughter paint?
The good part there is that you can fix it fairly easily by pulling the track around until the break is behind the mudguard.Was happy with the Carrier until the tracks snapped:
Unfortunately, the mudguard is already hiding the initial, and very untidy, join.The good part there is that you can fix it fairly easily by pulling the track around until the break is behind the mudguard.
That will make it a lot harder, yes … Pull the ends together with thread and stick some mud on it?Unfortunately, the mudguard is already hiding the initial, and very untidy, join.
It will have to be something like that. Probably buried into a base, but not exactly what I had planned initially.That will make it a lot harder, yes … Pull the ends together with thread and stick some mud on it?
Hi Neil, nice stuff. I have a question as this has happened the second time seeing it. The other is from my kitchen designers drawings. Are the images in perspective or is this the norm for 3D drawings, the vanishing point seems to come at you and not away into the horizon. I thought it was very Dali like...distorted. Even the base is on a slope...is there a slope?I haven't posted anything for a while, been busy 3D printing stuff for people. but my latest project is a model for a local architect, for which I have created a digital model from their 2D plans with a view to 3D printing most of it.
Here's the digital model-the scale is 1-60 to fit on a plinth they already have.
and here's the sample I made of a small section, to test the brick pattern and get their approval of the colours.
View attachment 493606View attachment 493607
A few tweaks required but we're good to go with the whole thing now. It will have lights so I've got to sort out the gaps around the window frames.
Incidentally , my airbrush died so it's all sprayed with rattle cans! They like it so I'm going with that for the finished article![]()
